73 Seat Belt Warning Buzzer - NCRS Discussion Boards
  • Peter G.
    • December 1, 1980
    • 406
    Where is the seat belt warning buzzer located. The Service manual looks like it is near the fuse box on the driver's side under dash?
    I believe it is off the wiring harness?
    Thanks.
    Peter Gregory # 4157
    National Corvette Restorers Society Since 1980
  • Jimmy P.
    • June 24, 2014
    • 1696
    Re: 73 Seat Belt Warning Buzzer
    Thanks.
    Hi Peter,
    Its located in the center of the dash. Yes, it is part of the wiring harness. You can get to it by removing the passenger side lower dash pad if I remember correctly. Here's its location as per the 73 AIM.
    Hope this helps!
    Jimmy
    1973 Convertible
    L48,M20,N40
    Mille Miglia Red/Oxblood
    • Peter G.
      • December 1, 1980
      • 406
      Thanks Jimmy..
      It was right in the middle of the passenger side dash. Replaced the missing buzzer and works fine.
      • Peter G.
        • December 1, 1980
        • 406
        Boy that buzzer is annoying!! Know wonder people removed it right away.
        • Jimmy P.
          • June 24, 2014
          • 1696
          Hi Pete,
          Glad to "HEAR" you got it working lol! I know what you mean about it being annoying at times. Remember, if you are not going on a long drive and just moving the car around at home or working on it, just pull the E-Brake handle up a couple clicks to disable it!
          Jimmy
          1973 Convertible
          L48,M20,N40
          • Harmon C.
            • August 31, 1994
            • 3228
            Just pull out the belt and wrap it around the buckle two times and tuck it under the seat, No buzzer because the switch is in the retractor in 73.
            Lyle
