GM Part number to GE Bulb Number - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5344
    From the 63 AIM. I've been looking for some time to convert the GM numbers to GE, anyone have an easy way.
    Bulb 74 1 B29.00 142453 15 1
    837 Back Window & Door Garnish Moldings, Headliner & Dome Lamp
    Bulb 141 6 C8.00 131282 5 1
    800 Voltage Regulator & Ignition Switch
    Bulb 192 12 B4.00 142453 4 2
    800 Instrument Panel Harness
    Bulb 192 12 B4.00 456985 8 1
    Bulb 193 12 B5.00 454626 21 12
    Bulb 193 12 B5.00 274004 25 1
    Bulb 193 12 B5.00 9412348 26 2
    Bulb 197 12 B9.00 274004 8 1
    800 Instrument Panel Harness, Switches & Cigarette Lighter
    Bulb 201 12 C3.00 142453 21 1
    800 Dome & Courtesy Lamp
  • David B.
    • March 1, 1980
    • 690
    Re: GM Part number to GE Bulb Number
    Harry, I noticed no one responded to your Jan. 15 thread re: "easy way to convert GM part #s to GE#". Chevrolet published what they referred to as a Special Interest Catalog. The one I have dated 10/1/61 answers/converts all bulb part #s to manufacture #s (pg 210 & 211). I do not know if this was done thru '63 but it appears the bulbs are the same based on your sheet. If you cannot find this catalog advise.
    • Rocco S.
      • December 21, 2013
      • 180
      I don't know if this would apply to the 1963 model year but the 1967 Corvette Owners Manual has a "Lamp Bulb Data" chart showing the bulb application, candle power and generic bulb number. Typical bulbs for the dash are 1445, 1816, 90, 257, and 1893. You can buy a complete set from Corvette Central but they are import bulbs with silver bases and may not have the proper candlepower. I just went thru this and after buying the kit I decided to buy NOS bulbs for everything. I found original Delco bulbs and some GE bulbs on ebay. Fairly inexpensive. All have the brass bases. The only pricey one is the #257 "blinking bulb" for the headlight motor warning.
      ROCCO SCOTELLARO
      1967 Lynndale Blue/Black Coupe L79, M21, G81 (3.70:1), A31, A82, C60, K66, N11, U69
      • Harry S.
        • July 31, 2002
        • 5344
        Rocco, thank you. Depending on your age you might recall train sets when you were a kid. The locomotive usually had a blink bulb. That bulb was the GE257. Search on Locomotive bulbs and might find them for 50 cents as I did a few years back.
        • Harry S.
          • July 31, 2002
          • 5344
          David, I don't have that catalog, is it easy to scan in the page and post it.
          • David B.
            • March 1, 1980
            • 690
            Not easy to scan but here are the numbers except for 274004. 142453 = 90, 131282 = 53, 142453 = 90, 456985 = 1891, 454626 = 1816
            9412348 = 257, 142453 = 90
            • Bob W.
              • December 1, 1977
              • 803
              Harry I looked at my brothers 66 owners manual and it has the same information as Rocco's 67. I don't have a manual for my 63 so I can't say if is listed in there.
              Bob
              • Harry S.
                • July 31, 2002
                • 5344
                Great, Thanks
                • Harry S.
                  • July 31, 2002
                  • 5344
                  Just found this online, 274004 looks to be GE 1445.
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11363
                    Found these charts on gmpartswiki.com searcing for 274004 (#1445)
                    • Richard M.
                      Super Moderator
                      • August 31, 1988
                      • 11363
                      Harry we were searching at the same time. I downloaded those 2 pages and saved as .png files and uploaded here in case their links ever go away.
                      Rich
                      • Bob W.
                        • December 1, 1977
                        • 803
                        Rocco The bulb kit you have from Corvette Central was it Lectric Limited kit or one that Corvette Central made?
                        Bob
                        • Rocco S.
                          • December 21, 2013
                          • 180
                          Bob and Others, I made an error this morning. The dash bulb kit I purchased was from Long Island Corvette Not Corvette Central as I originally reported. Sorry for the confusion. I believe the kit was made up at LIC as it did not have any other markings. It bulbs came in a fitted/divided plastic box with a list of contents, quantity and the application.
                          ROCCO SCOTELLARO
                          • Bob W.
                            • December 1, 1977
                            • 803
                            Rocco The bulb kit I have came from Paragon and is a Lectric Limited kit. The base of the bulbs are not silver but a brass color. So maybe they are two different kits.
                            Bob
                            • Patrick B.
                              • August 31, 1985
                              • 2011
                              I bought a Paragon bulb kit, and all the bulbs were generic silver base bulbs without a brand name but were marked China. I was very disappointed and there is no way I will use the bulbs in the instrument cluster, radio, clock and other inaccessible places. I bought a bunch of Sylvania long-life 1816 bulbs for $5 a pair, and to my chagrin they were also marked China. However, they had brass bases and were a name brand so I will used them. Ironically, very few of the 50 year old GE bulbs had actually failed, but it seemed foolish not to replace them with the dash apart which I never want to do again.
