Question for Joe Lucia and Our Engine Experts>Exact Length of Chevy BB Cyl. Bolts - NCRS Discussion Boards
  • Larry E.
    • 1692
    Building a 1968 L36 for display in my "mancave". Trying to make it as original in looks as possible. Block is
    made of HD plastic and is exact duplicate of the real block.(Went this route for weight) All add on parts
    (eg.-heads-oil pan-timing cover-intake manifold) will be the real parts. Question pertains to the cyl.
    head bolts. We know that the bolt size is 7/16 X 14 but need to know the exact length of these bolts
    (Both the long bolts and short bolts) Also need to know the typical head markings. Do not want to buy
    complete set of bolts(eg. Paragon and etc.) as I will not install them all. Will buy only the bolts I need
    from AMK. Need your help on this. Below is picture of my block in the cave. Thanks in advance-Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Gene M.
    • April 1, 1985
    • 4232
    Re: Question for Joe Lucia and Our Engine Experts>Exact Length of Chevy BB Cyl. Bolts
    Easy. If just for viewing measure the head thickness at the bolt holes and add 1/2”.
    • Larry E.
      • 1692
      Thanks Gene for the response but don't have the heads handy to measure what you suggest and also need the
      head markings of the bolts. Want to make the bolt order from AMK ASAP. Thanks--Larry
      Larry
      • Edward B.
        • March 29, 2013
        • 691
        Larry, see attached.
        The short bolt is 2" long and the long bolt is 4" long. (Note that they appear about an 1/8" longer than what they are, but that's only because of the angle I took the pictures from.)
        Markings are a plus sign with an M for the short bolts and a plus sign with an O for the long bolts, but I've seen other marking before.
        Ed
        • Mark E.
          • April 1, 1993
          • 4600
          Larry,
          What a cool project. If I was single, I would do something like this for the living room.
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
            • 43247
            Larry------
            The long bolts were GM #3877668. GM says these bolts were 4-1/2" in overall length. I've never measured any so I can't say, for sure. This part number is GM-discontinued but I expect you can find some on eBay. Even used examples will work for your purposes.
            The short bolts are GM #3877669. GM says these bolts are 2-1/16" in overall length. This bolt is still available from GM.
            • Edward B.
              • March 29, 2013
              • 691
              Joe, I agree on the long bolt (4.5" Overall), but boy, all my short bolts are 2.5" overall! I can't find ANY that are 2.0625" overall. I don't have a ton of them, but they are originals, so I can't see why such a difference between what I have and what the books say.
              Ed
                • 43247
                Ed
                Ed------
                GM spec for bolts often differ from reality. I don't know why this is. GM says that the bolts have the overall length I reported. However, I think that in the case of the 3877668, it is overall length that's specified at 4-1/2". In the case of the 3877669 I think that despite their use of the term overall length, what they mean is the shank length of the bolt (i.e. overall length minus height of the bolt head). This is actually the customary way to specify bolt length.
                • Edward B.
                  • March 29, 2013
                  • 691
                  Thanks Joe. Shank length is the way I was taught by my grandfather, a machinist for over 50 years, to measure bolt lengths. It seems strange that GM would specify "overall" length when it was an industry standard to use "shank" length. And in the case of the 3877668 and 3877669, one specified overall and the other shank!!! Very strange indeed.
                  Ed
                    • 43247
                    All-----
                    One other thing: on original big block head bolts the "cross" on the bolt head usually extends all the way to the ridge on the perimeter of the bolt head. Later bolts have the cross not extending all the way to the perimeter.
                    • Larry E.
                      • 1692
                      Ed------
                      FWIW: Made my order with AMK. To my surprise they had a bolt listed for the Chevy BB (Short Bolt) which they
                      claim is 2-1/16" in Shank Length. No bolt was listed for the (Long Bolt) so I had to find/look at other 7/16-14 bolts.
                      The one which was close was listed for the 260/289/302 Ford Heads. Shank length was 3.91". The head markings
                      short bolt did have the "+" marking but the long bolt has a "F" marking. Thanks for all the help>Larry
                      Larry
