Water Pump and crank pulley straightening - NCRS Discussion Boards
  • Kevin B.
    Infrequent User
    • February 23, 2007
    • 4
    I've been searching for a service that trues up pulleys. I must not be getting the correct terminology for the search. So, I'm asking for information on where I can get my wobbly pulleys straight so they run smooth vs. wobbly....... Thanks
  • Keith B.
    • September 15, 2014
    • 1600
    Re: Water Pump and crank pulley straightening
    if you put your pulley on a flat true surface what shim can you get to go under.
    • Gerry P.
      • October 28, 2007
      • 144
      As an FYI, I once had a wobbly water pump pulley and ultimately discovered it to be a bent water pump shaft.
      • Mark E.
        • April 1, 1993
        • 4607
        Right. I've seen many more bad bearings and shafts than bent pulleys. Also check the pulley/hub mating surfaces. So check these also.
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
        • Kevin B.
          Infrequent User
          • February 23, 2007
          • 4
          It's not bent shafts, etc. The pulleys themselves are a combo of out of round and "wavy". I'm looking for a service that can true up these pulleys. Anyone have a source?
          • Mark E.
            • April 1, 1993
            • 4607
            How did you determine the pulleys are out of round?
            A pulley is a part that doesn't often fails; even more extraordinary to discover several pulleys failing. That's why it may be worthwhile to double check what's going on.
            Mark Edmondson
            Dallas, Texas
            Texas Chapter
            • Steven B.
              • June 30, 1982
              • 4010
              A friend had one straightened years ago. Took it to a machine shop, made a circular 'donut' a bit smaller than the diameter of the pulley and thicker than mounting surface with pulley bolt holes and put it in a press so flat/back side of pulley and donut were flat against the press. Went slow and careful and no more wave. Most shops should be able to do it.
