1960 Hood Release Cable - Lubrication? - NCRS Discussion Boards
  • Daniel B.
    • August 11, 2016
    • 8
    Getting ready for PV with for a 1960. Does anyone have any tips/tricks for getting the hood release cable, repro or original (we have both), to return/reset unassisted?
    • 15678
    Re: 1960 Hood Release Cable - Lubrication?
    Use a dry graphite lubricant. They consist of a volatile carrier, which evaporates and leaves the spherical graphic particles that are a very good lubricant for high load, low speed applications. Examples are "Lok-Eze" and motorcycle control cable lubricants.
    • David H.
      • June 30, 2001
      • 1532
      DRI-SLIDE “Bike Aid” should be available at a motorcycle shop. Dri-Slide is packaged several ways however, Dri-Slide “Bike Aid” comes with a needle applicator handy for getting into tight places.
      Be sure to wear disposable rubber gloves as the graphite flows easily. Follow directions and shake container until you hear the mixing ball rattling around.
      Dave
