1970 M20: To avoid crunching, I double clutch into 4th. Sometimes it won't crunch if shifted very slowly.
1st through 3rd gears shift great going up or down the gears.
I heeded Joe Lucia's advice about carefully adjusting the clutch on these cars due to their limited travel. The clutch is adjusted for as much disengagement as possible with the pedal pressed, while still providing a minimum of free play when engaged (pedal at rest).
It has the proper level of fresh GM Goodwrench Gear Lubricant 80w-90.
Any tricks which may help 4th gear? Additives?
I tried synthetic oil, dinosaur oil, additives, etc. and nothing helped.
