What is this between upper and lower dashpads (1973)? - NCRS Discussion Boards
  • David C.
    • June 30, 2006
    • 126
    In looking at my 1973 dashpads (I have to remove to replace the headlight knob/rod), I noticed what appears to be tape or paper backing between the upper and lower dashpads on the driver's side. It may be part of / attached to the upper dashpad. I thought at first that the vinyl edge of the pad was coming away, but I think it looks more like a backing or tape of some kind.
    Does anyone know what this tape or paper is?
    Is there any specific care I need to take when removing the lower dashpad to access the headlight switch?
    Thanks for your help.
    Dave
  • Bill S.
    • April 30, 2002
    • 154
    Re: What is this between upper and lower dashpads (1973)?
    Looks like the vinyl has split and what you seeing is the foam that gives the dash its shape.
    Bill Strobel
    Owner Independent Towing
    Fayetteville, NC
    1979 Corvette White/Red L-82 4 spd
    Only 4,200 miles
    Do It Right or Don't Do It At All
    • Russ S.
      • April 30, 1982
      • 2163
      I don't think it is anything to be concerned about. It is just masking tape used to hold down the edge of the vinyl that has come loose.
      • John S.
        • June 15, 2015
        • 506
        David, not sure about the paper, tape or what ever is in the photo but I’ll give you my two cents worth on the lower panel and switch removal. I have replaced several HL switches successfully without dropping the entire LH panel.
        Remove the two screws that go into the LH panel from the gauge side, the three screws going up into the top dash pad and the three screws at the LH door jamb just above the hinges. That should loosen the panel and you should be able to get to the switch from the LH side. I prefer not to drop or remove the entire panel because that usually involves dropping the steering column and disturbing a bunch of the wiring harness behind the tach and speedo that can be a real pain to get back in properly.
        If you need a little more room to get behind the panel, you may have to loosen the column and drop it down slightly to gain additional clearance. Make sure you temporarily support the column so you don’t damage the rag joint at the steering box.
        Good luck and I hope this helps.
        1973 L82 M21 4 Speed, very original and well documented driver/survivor
        NW Chapter Member, 2016 Bend Regional Top Flight
        73/74 TIM&JG 3rd Edition Revision Team Member
          • 6950
          I agree with Russ, the factory does use tape at the edges of vinyl this on the lower pads also. once you drop down the drivers side to fix headlight switch you maybe able to re-tape??
          • David C.
            • June 30, 2006
            • 126
            Thank you all, I will report back once I have the dashpad off.
