1966 instrument panel harness repair questions - NCRS Discussion Boards
  • Steven L.
    • November 7, 2016
    • 32
    I've removed the dash cluster, with the entire harness attached, so that I can make some repairs to several damaged wires in the portion of the harness that goes through the grommet. Several of the wires (green/pink reverse light, pink ignition) have been cut or cut off at the point where the wiring went through the grommet, so I don't know how long they should be. Does anyone have a picture of that portion of the harness, showing those wires and their lengths?
    Steve
  • Keith B.
    • September 15, 2014
    • 1588
    Re: 1966 instrument panel harness repair questions
    The harnes is way past it’s service life. Why not replace it
    • Stewart L.
      • March 1, 1980
      • 355
      Here is an old 65 harness I have. It is an aftermarket but the lengths should be the same. The purple/black ignition wire is missing but it needs to be long enough to reach the resistor/TI harness depending on your ignition. The measurement begins where the wires come out of the main harness, not the firewall. Hope that helps.
