2004 TAC module source? - NCRS Discussion Boards
  • Bill B.
    Infrequent User
    • January 1, 1988
    • 6
    Anyone know of a source to buy or repair a throttle actuator module (TAC) for a 2004 base Corvette? GM no longer has or supports.
    • 6955
    Re: 2004 TAC module source?
    Bill, There is a company called BBA remanufacturing. Give them a call to see if they can help you. they refurbish quite a bit of electronic's. there are a world wide company, the source I use is based out of Taunton, Mass. 508-866-2740
    • Michael H.
      • December 1, 1987
      • 732
      Bill,
      You might check this out.
      Mike
        • 6955
        Mike , anything that was flooded may have a problem if the water got to the computer (s). and these cars computers all have to communicate with each other so that would mean re-programming any computer that is not part of the original car. the company I deal with above will reuse the original programed computer and repair if possible as long as it was not short circuited.
          • 43273
          Bill------
          The part you seek, originally GM #25311783 (new) and, later, GM #19245405 (remanufactured) is now GM-discontinued. However, you might still find a 19245405 at some Delco dealers. Otherwise, you can obtain a remanufactured module from autoecms.com. It won't be cheap, though---about 500 bucks with core exchange.
          • Bill B.
            Infrequent User
            • January 1, 1988
            • 6
            I talked to BBA and they can repair and warranty for 1 year for $290 - Will likely send it to them.
            Note: Their phone no. is 866 573-2740 Website: http://www.bba-reman.com
            Thanks to all!
