1957 Starter solenoid and battery cable nut - NCRS Discussion Boards
  • Dan P.
    • December 1, 1990
    • 683
    Were the 1/4 20 slotted screws that mount the starter solenoid to they starter painted black . Did the battery cable nut the one on the solenoid take a 1/2 or 9/16 wrench . I have both on the original solenoids i have .
  • Mike M.
    • May 31, 1974
    • 8409
    Re: 1957 Starter solenoid and battery cable nut
    I paint the solenoid attaching fasteners and prefer the nut requiring a 9/16" wrench. just my preference. don't have any documentation to support my opinions. mike
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11367
      1957 AIM Sec 12 Sheet 10 shows the Solenoid Battery cable nut as Part# 124829 3/8"-16. In the Standard Hardware pages I have(1929-1959), this Part # is described as a Check Nut(Lock/Jam nut) as opposed to a standard Hex nut. A standard 3/8-16 Hex nut uses a 9/16" wrench across the flats.
      However, I'm thinking the 124829 Check nut used the next higher wrench size, 5/8" ATF. I had some NOS Solenoids and they all came with 5/8" ATF nuts.
      Rich
      • David B.
        • March 1, 1980
        • 691
        Engineering Standards (1972) lists #124829 as HEX JAM NUT zinc 3/8 x 16 Nut thickness max./min. as .227/.210. " 9/16 Use corresponding nominal wrench opening for assembly tools."
