Best Engine Oil with enough Zinc - NCRS Discussion Boards
  • John M.
    • April 30, 2004
    • 111
    I was recently warned that most modern engine oils do not have any or enough zinc required by most older engines to keep the cam lobes properly lubricated. Is this true?? I have always used 10W-30 weight engine oil. Is there a specific brand anyone could suggest that contains the proper amount of Zinc?
    I just recently had my 1970 LT1 engine completely rebuilt and want to make sure I run the correct oil. I also have a 1967 L79 that I just purchased. The prior owner said the engine was rebuilt with only 6k miles since rebuild.
    Thanks John.
  • Leif A.
    • August 31, 1997
    • 3645
    Re: Best Engine Oil with enough Zinc
    John,
    I'm a fan of Shell Rotella Diesel oil 15w40, but any oil with a high ZDDP content should get the job done for you. If you want some in depth reading, the following is for you, written by some extremely knowledgeable folks (well known to many here).
    https://www.corvetteforum.com/forums...-corvettes.pdf
    Leif
    • Jim S.
      • March 13, 2013
      • 360
      Thanks John.
      Buy and add a bottle of ZDDPlus to any good oil.
      https://www.amazon.com/Engine-Oil-ZD...Cp_4%3AZDDPlus
      • Gene M.
        • April 1, 1985
        • 4232
        Brad Penn has a blend specific w/ZDDP. It’s for our older engines.
        • David P.
          • October 26, 2015
          • 49
          Driven Racing Oils - http://www.drivenracingoil.com/
          • Phillip M.
            • September 30, 2006
            • 100
            I concur with Gene. I've been using Penn Grade SAE 15W-40 (partial synthetic), for 5 years in my '67 300 HP engine with good results.
              • 15706
              I was recently warned that most modern engine oils do not have any or enough zinc required by most older engines to keep the cam lobes properly lubricated. Is this true?? I have always used 10W-30 weight engine oil. Is there a specific brand anyone could suggest that contains the proper amount of Zinc? I just recently had my 1970 LT1 engine completely rebuilt and want to make sure I run the correct oil. I also have a 1967 L79 that I just purchased. The prior owner said the engine was rebuilt with only 6k miles since rebuild.Thanks John.
              What you were told is a myth, but you are using the wrong oil.
              Easy web search - duke williams engine oil for vintage corvettes. It will answer all your questions including the ones you haven't asked yet. Enjoy the read.
              • Mark E.
                • April 1, 1993
                • 4600
                Ok, we did our quarterly oil thread.
                Is it time for another brake fluid thread yet?
                Mark Edmondson
                Dallas, Texas
                Texas Chapter
                • Darryl D.
                  • February 7, 2017
                  • 386
                  Why no FAQs like most sites have?
                  • Edward B.
                    • January 1, 1988
                    • 537
                    At least we could make Duke's article a "sticky."
                    • Ron G.
                      • December 1, 1984
                      • 865
                      John, Although the prior suggestions are more than adequate, I agree with Gene. I use Brad Penn SAE 10W partial synthetic. Last spring I had Mike McCale from G.H. Berlin located in Ease Hartford, CT do a technical seminar on zinc oil. You can reach Mike at (800) 426 - 7754 and can tell him that I suggested you call him if you take this route.
                      "SOLID LIFTERS MATTER"
                      • Joe R.
                        • May 31, 2006
                        • 1822
                        Hi John,
                        I would recommend going with what Duke recommends. He has the background and has studied the problem. There is a copy of his engine oil article in this newsletter starting on page 3.
                        Good luck!
                        Joe
                        • Michael W.
                          • April 1, 1997
                          • 4290
                          is there any evidence that the oils recommended by Duke are inadequate?
                          • Danny P.
                            • Today
                            I use to use the Sunoco Cam2 -20w30 , can,t find it anymore , I now use the Shell Rotella 15w40 it made for the older engine non Cat's system
                              • 15706
                              I just don't understand the internet obsession with Rotella. I find that Walmart usually has the best prices on C-category oil, and they usually stock the three major national brands and their own SuperTech house blend. Usually their Supertech 15W-40 is cheaper than the national brands, but sometimes a national brand is on sale and cheaper.
                              So I buy the least expensive one during my once a year purchase of two to three gallons.
