1954 Corvette rear tail light repair - NCRS Discussion Boards
  • Tim M.
    Infrequent User
    • July 14, 2012
    • 29
    Is it possible to re mount a 1954 Corvette reproduction plastic rear tail light lens in a used stainless steel bezel section. It looks like somehow the bezel was bent around the plastic at the factory on the original. Can this be done at home somehow? Thanks.
  • Chris S.
    • January 1, 2000
    • 1067
    Re: 1954 Corvette rear tail light repair
    very possible !
    first - (your going to hate this) - have to break the old one out
    you may be able to heat it up and twist the old one out - I have not tried it
    the new one will go in - use a light very small bead of silicone to seal it and keep it in place
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Tim M.
      Infrequent User
      • July 14, 2012
      • 29
      What type of silicone? Something like for household use like around a tub or something along the automotive use like a RTV blue. Thanks.
      • Steve M.
        • October 21, 2008
        • 59
        Clear household silicone worked for me. I had a loose lens. Just put a dab on my finger and reached in through hole in back and got it spread around neatly. Held like a champ. Here is where I then proceeded to throw away $500. Once the lens was fully cured in place I went through 1000 grit, 1,500 finishing with 2,000 grit, polishing compound and the thing was shining like a jewel nary a mark on them, as new.
        Then I had to give it one last light polish with my mini 2 inch buffer.. it caught and launched 10 feet out of my hand before shattering on the floor. But the million pieces are very shiny....
        • Tim M.
          Infrequent User
          • July 14, 2012
          • 29
          I hate it when that happens. Thanks for the silicone info.
          • Chris S.
            • January 1, 2000
            • 1067
            small small small bead on the inside lip - clear silicone
