1954 color/ sheen questions - NCRS Discussion Boards
+ More Options
Posts
  • Steve M.
    • October 21, 2008
    • 59
    I have the judging manual.
    I have Nolan Adams Book.
    I have 1,000 color photos from Troy Pyles of an early 54 and a late 54.
    I have researched as many photos online as I can find.
    I have been blasting and re painting all the brackets and chassis parts. I am doing up a spreadsheet of all the parts and what color/ sheen things are supposed to be. There are several items I couldn't determine the proper finish based on all the research above. (And likely more to come)
    So any input from experts would be appreciated. (I will post the final detailed list when done)
    1) sway bar
    2) rear end fill nut
    3) brake drums (semi gloss/ flat black or cast gray?)
    4) steering wheel and hub (gloss polo white and gloss sportsman red or flattened like dash?)
    5) convertible hinge cover (solid polo white or half/ half red/white)
    6) pumpkin cover bolts/ fasteners
    More to come, and appreciate all help here.
    Keeks
  • Chris S.
    • January 1, 2000
    • 1068
    Re: 1954 color/ sheen questions
    There is and should be different sheens
    Why - they were painted at different times by different painters and different paint
    Check Nolans book for good photos
    - the frame was coated in an a tar type paint which was a lower type gloss
    - The rear end was painted as an assembly
    - The complete front suspension was painted as an assembly minus the sway bar end links
    - Steering wheel - full gloss
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Steve M.
      • October 21, 2008
      • 59
      Thank you sir!
