Eaton Posi into a non Posi 67 - NCRS Discussion Boards
  • Al R.
    • June 30, 1988
    • 688
    As the title suggests, how difficult is it to install an Eaton posi unit into a non-posi housing on a 67 small block once the housing is out of the car? Is this something a local competent rearend/transmission shop can perform without too much difficulty? TIA for any advice. The rear end does need rebuilding, so I figured this would be a good time for the upgrade. TIA Al
  • Tom P.
    • April 1, 1980
    • 1815
    Re: Eaton Posi into a non Posi 67
    Basically, it's a bolt-in upgrade. Remove the ring gear from the non-posi differential and bolt it onto the posi differential, and set it up per the book.
    If you can do rearends, then do it yourself.
    • Gary R.
      • April 1, 1989
      • 1799
      As Tom said, it is a direct bolt in. Are you using a new loaded Eaton or building a better original 72 - 79 unit?
      • John D.
        • June 30, 1991
        • 875
        Lots of vids on youtube to get a feel for how its done.
        • Al R.
          • June 30, 1988
          • 688
          Thanks Tom and Gary. It will be a new Eaton unit. Anyone know of a source that can beat the Jeg's price of $559 with free shipping?
          • Tom P.
            • April 1, 1980
            • 1815
            With free shipping, that is probably about the best rate. ALTHOUGH, you might try Gears R Us.
            • Al R.
              • June 30, 1988
              • 688
              Thanks Tom! Ya'll have Merry Christmas and stay safe if traveling
