67 deck lid adjustment - NCRS Discussion Boards
  • Neal K.
    • October 31, 2007
    • 305
    My 67 convertible deck lid squeaks/rattles in the front corner behind the passenger seat. The overall fit looks very good. Is there a way to adjust the lid to get rid of the squeak. ThanksNeal
  • Russ S.
    • April 30, 1982
    • 2163
    Re: 67 deck lid adjustment
    The latch catch is adjustable up and down ward to tighten. Have you tried that?
    • Neal K.
      • October 31, 2007
      • 305
      • John L.
        • February 20, 2009
        • 186
        Russ
        Another thought. Take a peek under the closed Lid and make sure the Latch on the loose side is fully locking and is fully latched. It may have been damaged,...Open and inspect for proper operation and make sure its in the open position before closing again. Then you can open and adjust the striker down or up as needed.
        Also check the wedges to make sure they are in their place (one on each side of the lid and one on each side of the Body. Their purpose is to align the lid but there are "as required" shims that to can be added to remove any play (sometimes) once the lid is flush and level with the body sides. A little lube on the wedges and strikers can help with squeaks.
