car's in for the winter. thought it would be a good time to do an oil analysis. Reading the results are a bit beyond my pay grade.
oil analysis results Should I worry?
Re: oil analysis results Should I worry?
Boy, this does require interpretation by an expert, doesn't it?
No fuel or water, so that's a good sign.
Low magnesium... I know from personal experience this causes constipation.
FYI, I can read the info blacked out.Mark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
barring some drastic findings, a single oil sample analysis is virtually useless.- Top
- Top
OIIIIIIIIIL analysis can provide early warning of impending engine damage. To be effective multiple samples Must be taken at regular intervals an analyzed in a precisemanner.
Not really pracitcal or cost effective for the average enthusiast.- Top
Let me see if I can answer that! We as mechanics call it a trend, as in trend monitoring.
Dom- Top
Commercial fleet operators use oil analysis to see when an engine is approaching end of life when wear usually accelerates. Like Dom said, they look at the trend over the history of analyses for each engine.
It doesn't make a whole lot of sense for a collector car that sees only a few hundred to a few thousand miles a year especially if you have no reason to believe that the engine may be approaching end of life.
If the engine has good SOTP feel and performs as you think it should.... If not a proper tuneup and compression and/or leak down test is in order.
These vintage engines have high quality bottom ends... at least as built by Flint, but if the engine has been rebuild you may not know the quality of workmanship or parts.
Typically the first "problem" that will develop on an old engine is increasing oil consumption, which is often valve seals/guide wear or a valve may burn, but neither of these two issues can be predicted by oil analysis. Oil analysis is good at predicting excess bearing wear, but bearings are rarely the limiting engine life factor on car engines.
Duke- Top
