67 Tri Power Intake Manifold Date Coded? - NCRS Discussion Boards
  • Brian M.
    • April 4, 2011
    • 4
    I am experiencing some issues with my original intake manifold on my 67 427/435. If my original manifold is not repairable, what are my best options? Are they date coded? Can I get reproductions? anyone else gone thru this?
  • Russ S.
    • April 30, 1982
    • 2162
    Re: 67 Tri Power Intake Manifold Date Coded?
    Why wouldn't it be repairable? A good welder and machinist should be able to fix most any issue.
      • 11643
      Jerry MacNeish can work some magic with aluminum.
      • Michael F.
        • 745
        date code underside which can not be seen when installed
        Michael
        70 Mulsanne Blue LT-1
        03 Electron Blue Z06
        • Larry M.
          • January 1, 1992
          • 2694
          Agree with the other posters..........it should be repairable, especially with Jerry M. But if not, Coffman offers an excellent reproduction. They have/had two different dates codes for this manifold. But dates are on the underside and are generally not seen.
          David Crane also has used originals.
          Besides the cost $$$$ involved, you don't have a problem.
          Larry
