1963 Fuel Filter - NCRS Discussion Boards
1963 Fuel Filter
  • Sven C.
    • July 18, 2015
    • 189
    1963 Fuel Filter
    Going to change the fuel filter on a 1963 300hp and just wondering if anyone has an idea how much gas is going to spill out. Thanks for your help.
    1963 Corvette: Flight Judging Award (Top Flight) at 2023 Ontario NCRS Regional Meet (Regional) at 09-14-2023
    1963 Corvette: Flight Judging Award (Top Flight) at 2023 National Convention-French Lick (National) at 07-27-2023
    1963 Corvette: Flight Judging Award (Top Flight) at NCRS Indiana Regional (Regional) at 04-28-2022
    1963 Corvette: Flight Judging Award (Top Flight) at Ontario Chapter judging Meet 2021 (Chapter) at 09-18-2021
  • Jim L.
    • September 30, 1979
    • 1817
    Re: 1963 Fuel Filter
    If you disconnect the filter fittings immediately after shutting the engine off, there is a good chance the fuel like will be pressurized and you'll spray a few tablespoons of fuel. Probably not a good idea to do this.
    If you disconnect the fittings after the fuel pressure has bled down, you won't spill enough fuel to worry about. Do hold the full GF90 horizontal as you lift it away from the engine, though, since it will have fuel in it. Perhaps hold a rag under it to catch any slosh.
    Jim
    • Sven C.
      • July 18, 2015
      • 189
      Car is stored for the winter so no pressure in line/filter. Thanks for the advice Jim.
      • Bob R.
        • June 30, 2002
        • 1595
        Definitely put a rag under the filter before you start I'm sure you will get a little fuel running out but it shouldn't cause a problem if the rag is there.
        • Sven C.
          • July 18, 2015
          • 189
          Thanks Bob.
