Preservation vs. Restoration Questions - NCRS Discussion Boards
  • David M.
    • September 30, 2004
    • 533
    Re: Preservation vs. Restoration Questions
    WD40 comes in gallon cans, non aerosol (Grainger or Amazon), so you can dab it on. But why not spray it? It will creep into the outer hoop to center section gap too. If you want to avoid tire contact find or make a guard from thin sheet metal or plastic about 3" wide and long enough so it fits around the rim. Use binder clips to make the metal or plastic hold its circular form.
    Somebody makes these as I have a set but Ill be damned if I can find a pic online.
