1967 jack - NCRS Discussion Boards
1967 jack
  • Robert D.
    • April 1, 2003
    • 305
    1967 jack
    Does this appear to be an original jack dated march 67?
    thanx
    Bob
  • Joe R.
    • July 31, 1976
    • 4552
    Re: 1967 jack
    The jack and spring are correct for a 67 but I don't think the handle is correct for a 67.
    JR
    • Leif A.
      • August 31, 1997
      • 3654
      Re: 1967 jack
      Robert,
      I have attached pictures of my '67 jack (dated C7) and handle. They have both been judged several times with no deduct. Not to be contradictory with JR, but I think it all looks pretty good.
      Leif
      • Joe R.
        • March 1, 2002
        • 1356
        Re: 1967 jack
        I have made careful side-by-side comparisons of the Paragon repro '67 jack and a known original. The Paragon reproduction is an excellent reproduction, so it takes a very careful comparison to detect the subtle differences from an original.
        The referenced ebay jack looks original to me, and the price looks typical for an original jack. However, if you primary goal is getting a jack that will receive full credit in NCRS judging, the less expensive Paragon reproduction will probably work just fine. I used a Paragon reproduction for judging all the way up to the National level, and it always got full credit.
        While the differences between an original jack and the Paragon reproduction are (barely) detectable, they are very subtle, and most NCRS judges will give full credit to the reproduction. I think the reason is that there aren't many points assigned to the jack, so the deviations from an original are generally too small to justify a deduction.
        BTW, one thing that the judges do look at is the paint application, which should cover part, but not all, of the main threaded rod. Original jacks were dipped, not sprayed. Keep this in mind for whatever jack you decide to use.
        • Joe R.
          • July 31, 1976
          • 4552
          Re: 1967 jack
          Leif,
          You will notice the jack handle only has one hole in the top which is typical of earlier jack handles. Your handle has three holes, one on the top and one on both sides. Yours is more typical of 66-67 jack handles.
          JR
          • Russ S.
            • April 30, 1982
            • 2163
            Re: 1967 jack
            Joe, That is the side you are seeing with the one hole. No handle has only one hole with it being in the side. I expect this is a three hole and that we just aren't able to see the other holes due to light conditions.
            Originally posted by Joe Ray (1011)
            Leif,
            JR
            • Joe R.
              • July 31, 1976
              • 4552
              Re: 1967 jack
              Russ,
              Better check that again. I have to admit I'm half blind. Notice the way the socket is oriented! Well , it's sold anyway so if the new owner is happy I'm happy for him.
              JR
              • Leif A.
                • August 31, 1997
                • 3654
                Re: 1967 jack
                Leif,
                JR
                JR,
                You're absolutely correct...my eye didn't catch that but upon further review, pretty obvious. Thanks for making me aware.
                Leif
                • Daniel E.
                  • April 30, 2005
                  • 145
                  Re: 1967 jack
                  Bob,
                  The jack you reference looks correct to several known examples I have, but is bent/damaged/distorted at the end with the jacking nut. Not sure if it can be repaired
                  Daniel
                  • Robert D.
                    • April 1, 2003
                    • 305
                    Re: 1967 jack
                    Thanx guys i did purchase this jack ive been looking for one dated like this for along time. i think that bent area can easily be straightened out in a vise.
                    Joe were they dipped extended and held by one end which had no paint on that part of the rod
                    Thanx again
                    Bob
                    • Joe R.
                      • July 31, 1976
                      • 4552
                      Re: 1967 jack
                      You can find an old article in "The Restorer" that will assist you on painting the jack and identify the parts that should an should not be painted.
                      JR
                      • Grant W.
                        • December 1, 1987
                        • 407
                        Re: 1967 jack
                        Hello Joe
                        I can't seem to find my restorer magazine regarding original vs repop 67 jacks
                        What is the ( barely) detectable item that sets it apart?
                        I recall it maybe the Teeth at the bottom?
                        Here is one on ebay that just sold ebay item 133548981226
                        Thanks Grant
