?? on cast and stamped parts dates 1962 - NCRS Discussion Boards
  • Rick J.
    Infrequent User
    • September 4, 2017
    • 14
    Is there an NCRS judge I can call about a question on a C1.
    • May 31, 1974
    • 8411
    Re: NCRS judge
    what year c-1? if go to page 2 of any recent Restorer magazine, the c-1 team leaders contact info is therein. mike
    • Don H.
      Moderator
      • June 16, 2009
      • 2287
      Re: NCRS judge
      Rick
      why don't you post your question here. and perhaps ask for a pm or an email from someone with first hand knowledge.
      Likely several with vast judging experience will answer your request. In fact, someone already has.
      • Rick J.
        Infrequent User
        • September 4, 2017
        • 14
        Re: NCRS judge
        It's a 62. I don't get restorer magizine sorry.
        • Gary B.
          • February 1, 1997
          • 7098
          Re: NCRS judge
          Rick,
          The National Team Leaders are listed under Contacts on the DB website main page. No need to go to the Restorer.
          Gary
          • Rick J.
            Infrequent User
            • September 4, 2017
            • 14
            Re: NCRS judge
            Nolan Adams book on Restoration 53-62 Vol 1 has on page 392 paragraph 3 & 4 says engine blocks and parts have dates cast into them. Yes! Now paragraph 4 says Date coding was alphabetical and the letter "I" was omitted.
            So if a block casting date on the rear has J... that is Sept. The stamping on the front of the block also is stamped F09... However NCRS judging manual says J is Oct. This throws the stamping date off. What's up with all that? Any help would be appreciated.
            • Rick J.
              Infrequent User
              • September 4, 2017
              • 14
              Re: NCRS judge
              Ah thanks Gary. I'm new to this what's DB?
              • Gary B.
                • February 1, 1997
                • 7098
                Re: NCRS judge
                DB = Discussion Board. What you're posting on.
                Gary
                • Rick J.
                  Infrequent User
                  • September 4, 2017
                  • 14
                  Re: NCRS judge
                  Oh of course. Thanks for your patience.
                  • Loren L.
                    • April 30, 1976
                    • 4104
                    Re: NCRS judge
                    If you've got a membership # and are NOT receiving, the Restorer/Driveline, you MIGHT want to contact Publications..........
                    • Mike E.
                      • February 28, 1975
                      • 5153
                      Re: NCRS judge
                      Casting dates include an I for month designation. (September). The J would definitely indicate October.
                      Stamped dates that use a letter for a month designation almost always skip the I, so in that case, J indicates September. (Starter, regulator, distributor, generator, etc.
                      block assembly date stamping (on the front pad) can be a little confusing, because they used an I character to designate a 1.
                      If you have additional questions on your 62, I would be glad to help. I have a bit of experience with them.
                        • 15646
                        Re: NCRS judge
                        I think that is a bit of an understatement.
                        • Vinnie P.
                          Editor NCRS Restorer Magazine
                          • May 31, 1990
                          • 1584
                          Re: NCRS judge
                          I'll second that!
                          • Rick J.
                            Infrequent User
                            • September 4, 2017
                            • 14
                            Re: ?? on cast and stamped parts dates 1962
                            Yes I'm a member. Thanks for that.
                            • Rick J.
                              Infrequent User
                              • September 4, 2017
                              • 14
                              Re: NCRS judge
                              Ah thanks Mike. Ok. The casting date code on the block is J251. The stamped code on the front of the block is F0928RF. I'm confused.
