65 396 rear carrier and rear case casting numbers - NCRS Discussion Boards
  • Larry S.
    • May 23, 2015
    • 15
    HELP
    Have not been able to find casting number for the differential rear end case number nor the rear cover for the 1965 396. Looked in ncrs 65 Judging Guide and Nolan Adams Restoration 63-67. Anyone out there that can provide this info?
    Larry Smith
    • 43273
    Re: 65 396 rear carrier and rear case casting numbers
    Originally posted by Larry Smith (61238)
    HELP
    Larry Smith
    Larry------
    Carrier housing
    early (through about 2/65)------3818753
    late (after about 2/65)-----------3876476
    cover-------3871375
    • Larry S.
      • May 23, 2015
      • 15
      Joe,
      Larry
      • Larry S.
        • May 23, 2015
        • 15
        Joe,
        Was the rear cover dated??
        Larry
          • 43273
          Joe,
          Larry
          Larry------
          Yes, they were.
          • Mike D.
            • July 31, 1996
            • 311
            From vin # 17552
            Larry[/QUOTE]
            Mike Doty
            Intermountain Chapter Judging Chairman
            Region VIII Director
            • Larry S.
              • May 23, 2015
              • 15
              Joe.
              I found a differential carrier cast date 12-28-65 Casting number 3876478. This was to late for 65 396 what car does this rear end number go on?
              I am still looking for the case number you gave me for the 1965 396 which was 3876476, correct?
              Larry
                • 43273
                Joe.
                Larry
                Larry------
                There was no 3876478 carrier housing. The last digit is a "6" although it may look like an "8". That's a common problem with casting numbers. The 3876476 was used from 1965 through 1979.
