C2 dash bulbs - NCRS Discussion Boards
C2 dash bulbs
  • Randy R.
    • March 1, 1983
    • 477
    C2 dash bulbs
    How many 1816 dashboard illumination bulbs are required for a 67?
    Where can I obtain replacements that are made in the USA?
    The dash lights were replaced with a kit from a Corvette supplier. I believe they are imported. They are dim. The headlight switch is original.
    Thank you,
    Randy
  • Russ S.
    • April 30, 1982
    • 2163
    Re: C2 dash bulbs
    Ebay. There are NOS USA made bulb. there
    • Patrick C.
      • January 16, 2013
      • 327
      Re: C2 dash bulbs
      I thought there were some brighter lights available with the same mount? 1817?
      • Jim S.
        • March 1, 1986
        • 1408
        Re: C2 dash bulbs
        Randy,
        There are 14 , I believe. 11 in the gauge cluster ,2 for the clock , and 1 for the radio.
        I got all my 1816s as well as every other bulb needed off flea bay . I too heard that the old "Made in the USA "bulbs work better then the new ones as well as having the brass bases . So even though I also bought a kit from a corvette parts place I hunted down all the numbers I needed seperately on line .The ones I scored were mostly GE or Westinghouse bulbs . Except I also found that AC Delco makes and sells , or at least did , a box of 10 1816s that are made in Hungary of all places , but still had the brass bases.
        There may be other sources for the bulbs from guys here on the forum as well.
        Jim
        • Gary J.
          • April 1, 1980
          • 1245
          Re: C2 dash bulbs
          Saw an ad in the Driveline that Joe Perri has nos sets available. No price given.
