Spicer u-joint part numbers - NCRS Discussion Boards
  • Bob W.
    • December 1, 1977
    • 803
    I have a1969 350/ 300 hp 4 speed car and I would like to install new u-joints.Can anyone tell me the part numbers for spicer u- joints.
    Thanks Bob
    • 43273
    Re: Spicer u-joint part numbers
    Thanks Bob
    Bob-------
    Driveshaft------5-1310X
    Half-Shaft------5-1350X
    The above are "lubed-for-life", non-greaseable u-joints, as-original. However, these are not configured like original u-joints as they are forged powder metal construction.
    The following are greaseable type Spicer u-joints that grease through the end caps rather than the body of the joint. They are also of forged powder metal construction. However, they are considerably more expensive than the above.
    Driveshaft------5-13101X
    Half Shaft------5-13501X
    • Bob W.
      • December 1, 1977
      • 803
      Joe Thank you for the quick reply. With them not like originals they will work and do you feel this is my best choice?
      Thanks Again Bob
        • 43273
        Thanks Again Bob
        Bob------
        Yes, these will work just fine. Unless you are concerned about maintaining original configuration (for a component that only a judge might see), I consider these to be your best choice. These u-joints are about 2-3 times as strong as the original u-joints or many other aftermarket replacements.
        • Bob W.
          • December 1, 1977
          • 803
          Joe Thanks again !!!!
          Bob
          • Gary R.
            • April 1, 1989
            • 1804
            Bob
            As mentions these UJ's are very good but have larger crosses. The original flanges and yokes may need to be radiused to allow the spicers to fit. It's not much but most times I have to, unless I am using new flanges those are ok.
            • Richard G.
              • July 31, 1984
              • 1718
              These Joints have the variable thickness color coded snap rings. They are different thickness and should be set up with .002 end-play.
              Different than what most have people have dealt with.
