I have a 65 L84 car that runs as it should but the Oil pressure is way to high (65-70 lbs at hot idle). Obviously to high for proper operation and certainally to high for a PV. I have the oil pump out and it is a GM pump which was installed on the motor when it was rebuilt in the mid 80's. Main casting is GM2796 and the lower casting is GM176 with 4180 below it. Looking for advice as to wether I should try to change the spring on my existing pump or just install a new stock pressure pump. The spring is held in by a small drive pin which look like it may be difficult to remove. Seems Melling 55 would be the proper choice for a replacement.
Any guidance is appreciated.
