Where to get correct radiator core? - NCRS Discussion Boards
  • Mark A.
    • February 1, 1996
    • 299
    I'm restoring a 69 435hp coupe. The radiator in there now is a replacement copper unit, but has 3 stamped holes on top, instead of 2. It is also 2.5" wide instead of 2". DeWitts seems to make only aluminum replacements. Does anyone know if someone else makes a correct copper radiator for the 427? Thanks, Mark
  • Russ S.
    • April 30, 1982
    • 2163
    Re: Where to get correct radiator core?
    Have you checked with a radiator shop on the configuration of a replacement core? Do you have the correct tanks that could be installed on a new core?
    • Mark A.
      • February 1, 1996
      • 299
      Russ,
      I have not checked with a radiator shop. Do they have access to cores that I can't get? And yes the tanks are the correct Harrison tanks. Mark
      • Russ S.
        • April 30, 1982
        • 2163
        They used to have correct cores for my 73s and then they changed the shape of the top and bottom bar so I took them my original core which they then sent to wherever they get their re-cores and had the core company use my original top and lower support bar putting them onto the new core. Turned out great.
        • Mark A.
          • February 1, 1996
          • 299
          Problem with mine is the core is wrong. the shop would have to be able to get a correct core.
          • Russ S.
            • April 30, 1982
            • 2163
            That's what I needed also. I was in Denver at the time and went to Gold Star Radiator with by bad core and good top and lower bars. They removed the tanks and bars then sent the bars to their core supplier who made a new core using my correct bars. They then sent the new core back to Golds Radiator to have the original tanks re-installed.r
            • Mark A.
              • February 1, 1996
              • 299
              My top and lower bars are wrong. 3 holes instead of 2.
                • 6956
                Mark, try calling Dewitt's . I am pretty sure they have the correct core or Radiator assy. also you want the attaching code tag and overflow hose retainer clip (s) for judging, I think 69 has these? some of the venders sell these I think it maybe Paragon Corvette.
                • Gary J.
                  • April 1, 1980
                  • 1246
                  Go to Dewitt's web site and look under restoration radiators. $899.00 They usually have a sale the first of the year.
