Question 63 close ratio tooth count - NCRS Discussion Boards
    • 6956
    Does anyone know the gear tooth count on the 63 close ratio 4 speed??
  • Peter M.
    • May 30, 2013
    • 360
    Re: Question 63 close ratio tooth count
    Ed,
    If it's a Muncie the main drive (clutch) gear is 26T. The cluster is 27T,22T, 19T, 17T.
    If it's a Borg Warner I would have to do some looking.
    Kind regards
      • 6956
      Pete , yes it is a Borg Warner t10 , I should have post the Trans type. Thanks Ed
      • Chris D.
        • November 1, 2002
        • 198
        Made me look. 27t main drive gear, cluster 28, 23, 20, 17 for the close ratio Borg Warner box.
          • 6956
          Chris is it possible that the C/R cluster gear tooth count for 63 t10 is- 28,23.19.17. I found a nos cluster gear with this gear count. Thanks, Ed
          • Chris D.
            • November 1, 2002
            • 198
            • Chris D.
              • November 1, 2002
              • 198
              Ed,
              You're right, it has to be 19 for the listed 1.64 second gear ratio to calculate correctly. 30/19 * 28/27 = 1.637. I either misread the parts book or need to make a correctional notation. Looks like you have the cluster you are looking for.
              Chris
                • 6956
                Chris I believe your first post on tooth count is correct, I found that the 63 Corvette tooth count with the t10D trans case is different as the t10C case is different than the D case. the part number listed as 3813379 is 63 corvette. the C case is 3813378 which must be pass car C/R cluster gear?????
                  • 6956
                  if anyone else along with Chris can shed some light on the tooth count(s) please weight in. Thanks Ed
                  • Ray K.
                    • July 31, 1985
                    • 375
                    My books list B / W main drive gear 2.20 close ratio as 27 tooth count for 1963 # 3855734
                    cluster gear count is 28-23-19-17 for 2.20 ratio # 9771378 ( old number #3817378 )
                    #3817379 cluster gear is 2.54 ratio - 30-23-19-17
                    Ray
                    • Timothy B.
                      • April 30, 1983
                      • 5201
                      I always thought the tooth count was different on the cluster gear on the D case because the second gear on the D case mainshaft D had a different tooth count.
                        • 6956
                        Tim, I have been doing a lot of searching on TDB archives as it looks like the input and cluster gear is what I need to convert my wide ratio to a close ratio, it also appears as though the other gears are the same.
                          • 15706
                          That's the expedient GM used to create the two ratio sets. Only two parts are different, the clutch gear and countergear. Unfortunately it results in 1-2 and 2-3 being fairly close (same intergear ratio for both CR and WR versions), and then there's a huge gap to forth.
                          It should be the other way around - the widest gap between 1-2, the progressively closer as you move of the gears.
                          The Richmond Super T-10 is what I call a progressive ratio transmission with a choice of three gear sets, with first gears of 2.88, 2.64, or 2.43. The widest gap is between 1-2 and gets closer through the gears.
