DOT 5 - Is this new to anyone else? - NCRS Discussion Boards
    • 43285
    #91
    Re: DOT 5 - Is this new to anyone else?
    Originally posted by Gerald Coia (11656)
    Thanks Don
    Gerald------
    Be aware that DOT 5 silicone fluid is dyed purple when it's fresh. After it's been in a brake system for awhile the color changes to yellow. While it's a deeper yellow than DOT 3/4, it can be confused with those fluids.
    • Gerald C.
      • June 30, 1987
      • 1311
      #92
      I believe it was this thread that I asked how to tell the difference between Dot 4 and Dot 5 brake fluid. I was told that Dot 4 mixes with water and Dot 5 separates from water. When I removed my M/C, I tested the brake fluid by mixing it with water. The brake fluid stayed mixed with water, so I'm under the belief that I have Dot 4 in my brake system. I am not going to drain the brake lines when I re-install the M/C, so I will stay with the Dot 4 brake fluid.
      FYI..
      Jerry
