C1 lower control arm outer pin - NCRS Discussion Boards
  • James F.
    • March 1, 1997
    • 51
    I'm assembling the pivot pin thru the control arm & steering knuckle. There is the pin, 2 o-rings, a serrated washer & a nut. Do the o-rings go in between the inside of the arm & the knuckle? They don't seem thick enough to seal. These parts are from Paragon (closed thru the weekend). Also, I would think that the head of the pivot pin goes right up against the control arm. Thanks, Jim
  • Terry D.
    • May 31, 1987
    • 2697
    Re: C1 lower control arm outer pin
    James
    Search this forum for Tom Parsons and Richard Mozzetta, I believe both have addressed this problem
    • Eric E.
      • November 1, 1998
      • 254
      • Dan P.
        • December 1, 1990
        • 683
        They go between the a arm and the threaded bushing that screws in the knuckle. To keep the dirt out of the lower threaded bushing that screws in the knuckle.WHne you grease it this were the grease comes out .
        • Dan P.
          • December 1, 1990
          • 683
