C2 brake light switch removal - NCRS Discussion Boards
  • Randy R.
    • February 28, 1983
    • 477
    How do I remove the brake light switch on a 67?
    Thank you.
    Randy
  • Bob R.
    • June 30, 2002
    • 1595
    Re: C2 brake light switch removal
    The brake pedal assembly has a bracket on it with a hole and the brake light switch is attached to that bracket with two bolts. Just remove the outer bolt and the switch should come out. Sounds simple and probably was when you were twenty but not some much now. There are a lot of wires and other things in your way.
