Another carpet install question 66 - NCRS Discussion Boards
  • Jim S.
    • March 1, 1986
    • 1408
    After viewing 50 plus carpet posts and still not finding my answer, I now look to you .
    On the passenger side front; {1} Does the underlayment and carpet go only up to the edge of the lip of the duct work, or over the lip ?
    {2} Is it a straight cut either way or can you add and or leave a little extra on either end ? In Other words follow the curvature of the duct work
    Anybody got a great picture of that area completed ?
    Jim
  • Donald H.
    • November 2, 2009
    • 2594
    Re: Another carpet install question 66
    Not sure if this helps, but my carpet on the passenger side comes up the foot well and touches the bottom of the heater box assembly. I wanted to hide the foam insulator that goes around the heater box on the inside. I lost one point at Regional with a comment "Long next to heater core & well".
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
    • Jim S.
      • March 1, 1986
      • 1408
      Don,
      That gives me a better idea. Thanks .
      Sure would like a good picture of that area by someone sure of their finish , or from an original carpet vette . Hint hint
      Jim
      • Peter M.
        • May 30, 2013
        • 361
        Jim,
        My 67 coupe has the original carpet, but it is out of the car. I can take a picture of the carpet if you would like and I can put it back in the car and take a picture if necessary.
        I think 67 is close to the same as 66.
        Pete
        • Jim S.
          • March 1, 1986
          • 1408
          Pete,
          Sounds like a lot of trouble to me ,(reinstalling it ), lets wait and see if someone else chimes in first.
          Jim
          • Peter M.
            • May 30, 2013
            • 361
            Jim,
            It won't be much trouble, don't hesitate to ask if no one chimes in.
            Pete
            • Jim S.
              • March 1, 1986
              • 1408
              Pete .
              Well no one has , so if you wouldn't mind ?
              Thanks ,
              Jim
              • Peter M.
                • May 30, 2013
                • 361
                Jim,
                I should be able to do it in the next day or two.
                It will be a nice break from cleaning the underbody.
                Pete
                • Peter M.
                  • May 30, 2013
                  • 361
                  Jim,
                  Here you go. If you want more photos or measurements just let me know.
                  Pete
                  • Jim S.
                    • March 1, 1986
                    • 1408
                    Thanks a lot Pete, I do appreciate it !
                    So if I see this correctly , on your original carpet , The underlayment goes up to the lip and the Carpet actually covers The lip .
                    I wonder if that was the way Don Harris" car was , and if that's what he got dinged for ?
                    Jim
                    • Peter M.
                      • May 30, 2013
                      • 361
                      Jim,
                      In the picture with the carpet pulled back you can see the underlayment has been cut, I don't know if this was done at the factory or not. I don't think the carpet on that side had ever been removed before but who knows.
                      Where the underlayment buts to the bottom of the dash the carpet flap extends about 1 1/4".
                      If you want anything else let me know.
                      Pete
                      • Donald H.
                        • November 2, 2009
                        • 2594
                        Here's a picture of the same area in my 66 coupe. I think mine looks pretty close to the same fit as Pete's, so I'm not sure what the judges at the regional saw that they didn't like.
                        I do have my jute padding stopping at the bottom of the heater flange, i.e. it does not touch the heater box. One thing that I see missing in Pete's pictures if the foam insulator (66 AIM UPC 1 ASM sheet D6 item #2). I had forgotten to install this foam piece when I was finishing the restoration and the interior judge at the chapter meet (he was a 66 national team interior judge) dinged me for that but he didn't say anything about the carpet being to long.
                        I installed the foam insulator before the regional meet. Not exactly easy to do after the fact, but I was able to get it installed.
                        Don
                        Don Harris
                        • Peter M.
                          • May 30, 2013
                          • 361
                          Don,
                          My car has air conditioning. I think the configuration is a little different regarding the foam insulator.
                          Pete
                          • Jim S.
                            • March 1, 1986
                            • 1408
                            Pete,
                            Thanks again for the effort and the confirmation.
                            Don,
                            Your picture confirms what I thought you explained in your first post . So I don't know what the Judges saw either .
                            As for the Insulator, you had me worried for a moment there, as you can't see mine either ! Pete hit it on the nose however , A/C cars use a different gasket. See UPC C60 A2 Item #1
                            Jim
                            • Donald H.
                              • November 2, 2009
                              • 2594
                              Yep I see the difference with A/C versus non-A/C in mounting of the heater box and other bits.
                              Don
                              Don Harris
