On a 64 mine is plated (yellow, likely yellow zinc) and then painted black. They AIM calls for two parts spot welded together and I guess then painted. So I'm pretty sure I have a repro but the question is this. Should there be plating?? I doubt it. Paragon sells a repro which is plated and that may be where mine came from.
Battery Hold Down/Shield Plated?
Re: Battery Hold Down/Shield Plated?
Larry------On a 64 mine is plated (yellow, likely yellow zinc) and then painted black. They AIM calls for two parts spot welded together and I guess then painted. So I'm pretty sure I have a repro but the question is this. Should there be plating?? I doubt it. Paragon sells a repro which is plated and that may be where mine came from.
I'm not real familiar with this part. However, I can tell you this: GM component parts may be either plated or painted. Sometimes, the GM spec for the part allows the manufacturer to apply either finish, optionally. However, I don't know of a single case in which any GM part receives both plating and painting. If painted, it's usually over bare metal.In Appreciation of John Hinckley- Top
