About the three speed transmission - NCRS Discussion Boards
  • Paul P.
    • January 10, 2012
    • 96
    Hello:
    I'm in the process of researching an article for my vintage Corvette club, the subject being transmissions.
    I have some questions on the three speed manual, first seen in 1955, last seen in 1969.
    I've attached a couple of photos I took of a three speed manual transmission demo that I found at an overpriced automobile memorabilia store. I recall that there is an industry name for these, not sure what it is. It is labeled as a "'57 Chevy 3 Speed". My first question: is this the same as found in the Corvette?
    Another thread has the later three speeds featuring synchro first gear, true?
    One 1958 three speed owner said it really wasn't a good sports car transmission, besides not offering a fourth gear. He claimed it originated as a truck transmission and the linkage did not offer good sports car shifting characteristics. Any opinions? Have not driven one myself.
    I put a quickie spread sheet together (available at http://corvettestory.com/temp/Three_...ual_Notes.xlsx) covering the quantities from 1957 to 1969. It is derived from the Corvette Black Book data. Basically I totaled up all the other transmission quantities and subtracted them from the production quantities to get three speed manual numbers. It shows 252 for 1969 and 919 for 1963 for example. I did this as I've never seen a three speed manual C2 or C3 and was curious.
    Any comments on the spreadsheet or the process are welcome.
    ~paul
  • Keith W.
    • June 30, 1998
    • 375
    Re: Aout the three speed transmission
    Paul
    I have a 66 with 3 speed - non ordered radio - base engine
    • Jim L.
      • September 30, 1979
      • 1816
      Paul,
      The pictured transmission is, indeed, for a '57 passenger car. It is a wide radio box with 2.94 low gear. Corvette 3 speeds would have had a 2.2 low gear and a boss on the tail shaft for shifter mounting. 1st gear is not synchronized.
      Jim
      • Todd H.
        • 120
        Paul,
        The original owner of my '57 told me that the 3 speed in our car was so bad that he simply threw it away when he replaced it with a 4 speed immediately after buying the car in 1957. He said there was no way that anyone would buy it, and why hang on to a worthless transmission? He wanted 4th gear, but the lack of the first gear synchro was just as bad as no 4th to him.
        Of course, he wasn't looking for a grocery getter. He wanted to go racing.
        • Paul P.
          • January 10, 2012
          • 96
          Jim:
          Cool.
          For the purposes of my article, it looks like I would be accurate saying that the "transmission shown in the photo is from a 1957 passenger Chevrolet which is similar to the three speed transmission installed on the Corvette".
          Interesting. I assume the lack of a boss on the tail shaft is due to the standard passenger car having a steering column mounted shifter?
          ~paul
          • Paul P.
            • January 10, 2012
            • 96
            Todd:
            I love hearing those stories. Times and circumstances sure have changed!
            ~paul
            • Gary C.
              Administrator
              • October 1, 1982
              • 17780
              Paul,
              FYI - early Restorer Magazines there were several good articles written on 3 speed transmissions by Paul Hendrickson.
              Gary
              NCRS Texas Chapter
              https://www.ncrstexas.org/
              • Jim L.
                • 1816
                Originally posted by Paul Pollock (54300)
                Jim:
                Cool.
                That would be accurate.
                ~paul
                True. There was no need for the shifter mount bosses in passenger applications.
                Oh, and another difference in the tail shaft housings was the presence of a transmission mount boss in Corvette applications. Not needed in passenger applications since the transmission hung out in space, being supported by the four bell housing attachment bolts.
                And as long as I'm doing a brain dump of what little I know about 3 speed transmissions: Beginning in '57, the side cover incorporated a mechanical interlock which prevented being able to select two gears simultaneously (like 3rd and reverse, for example). In your picture, you can see this interlock. It was not present on '55 and '56 side covers.
                Jim
                • Gary C.
                  Administrator
                  • October 1, 1982
                  • 17780
                  Jim,
                  Also, in March '57 the shift gift was enlarged on 3 speeds. IIRC the shift gate was the same as a 4 speed.
                  Gary
                  NCRS Texas Chapter
                  • Gene M.
                    • April 1, 1985
                    • 4232
                    Last year of non synchro was 65. It had mounting for the shifter. The synchro version had to mount shifter to frame mount only. The tranny changed entirely in 66 to full synchro. Still cast iron case into 67. I donโ€™t know after that.
                    • Jim L.
                      • 1816
                      Originally posted by Gary Chesnut (5895)
                      Jim,
                      Gary
                      Not sure I'm following you, Gary. Are you saying that shift lever travel for 3 speeds increased?
                      • Gary C.
                        Administrator
                        • October 1, 1982
                        • 17780
                        Jim,
                        Top of the shifter housing where the shifter handle goes through.
                        Gary
                        NCRS Texas Chapter
                        • Gary C.
                          Administrator
                          • October 1, 1982
                          • 17780
                          Screenshots of the different shifters from the 1957 AIM. After the 4 speed was introduced in April '57, the 3 speeds used the same bracket with the large shifter opening.
                          NCRS Texas Chapter
                          • Jim L.
                            • 1816
                            Thanks, Gary! That clears it up perfectly.
                            Learn somethin' new every day.....
                            • Gary C.
                              Administrator
                              • October 1, 1982
                              • 17780
                              Jim,
                              Somewhere in the C2's the tailshaft design was changed, but that's above my wheelhouse.
                              There's some other tailshaft changes in 56-7, but I'd have to dig out my archived cliffnotes.
                              Gary
                              NCRS Texas Chapter
