Today, my plan was to install my doors.  The drivers side went on without any issues and lined up perfectly.  The passenger side...not so much.  I had some challenges...  When I removed both doors, each fit just fine with no issues.  Today, no matter how I attempted to align the passenger door, it continued to touch at the top near the windshield area.  We even took the door off and swapped the top and bottom hinges...but hence the same issue. It's like the door is cocked where the top sits more inward than the bottom.   I know I can fix it by sanding down the body side where it's touching, but I thought I'd try asking the experts first.  Any ideas on what I can do?  Should I try adding a shim at the top hinge?
See the attached pictures for reference.
Thanks.
Jill, 59140
Thanks.
Jill, 59140
 C1 (59) Door Alignment Help Needed
