wiring harness - NCRS Discussion Boards
wiring harness
  • Roy A.
    • January 20, 2015
    • 17
    wiring harness
    my name is Roy Abriani 60846. I am getting ready to order a complete wiring harness for my 57 vette. Which harness manufacturer would you recommend I use?
  • Mike M.
    • May 31, 1974
    • 8382
    Re: wiring harness
    lactic limited. they ad in the driveline. tell us about your 57. mike
    • Don H.
      Moderator
      • June 16, 2009
      • 2257
      Re: wiring harness
      wait a minute, Mike. Lactic! He doesn't want milk!
      Lectric.
      (but I know you know that.....)
      • Mike M.
        • May 31, 1974
        • 8382
        Re: wiring harness
        Don: he well may be in need of mammary juice. mike
        • Patrick S.
          • January 1, 1988
          • 209
          Re: wiring harness
          I just put an Electric Limited harness in my 57, the fit was great.
          • Ed H.
            • November 1, 1999
            • 626
            Re: wiring harness
            Roy,
            I used Lectric Limited on my 57. Worked great. If you do not have interior lights don't worry about the extra wires under the dash,
            they is used for that purpose. I would suggest you add an extra ground wire of good size gauge and add it to one of the screws used
            to mount your fuel level gauge. Grounding has always been a problem in early and mid year cars. You will know if you have a problem,
            it shows up when you apply one of the turn signals, the gas gauge will jump the the same beat as your turn signal flasher. I would suggest you order the plastic covered wiring diagram they also provide.
            • Patrick T.
              • September 30, 1999
              • 1286
              Re: wiring harness
              I have an Electric Limited wiring harness in my '57 as well, no problems and the fit was great.
              • Michael L.
                • December 15, 2006
                • 1390
                Re: wiring harness
                I need to order a harness for my 69. Would you recommend Electric for my year too?
                Mike
                • Patrick T.
                  • 1286
                  Re: wiring harness
                  I just checked the price of a Lectric Limited '57 wiring harness. WOW- $643 that must be twice the amount I paid back in 1989.
                  • Mark S.
                    • July 31, 1983
                    • 660
                    Re: wiring harness
                    Not to be a spoiler here; but the wires on my Lectric Limited 56 main harness were not long enough to connect my horn relay.
                    • Ed H.
                      • November 1, 1999
                      • 626
                      Re: wiring harness
                      Mark, Sierra Hotel, I know you made it work.
