67 rear script - NCRS Discussion Boards
67 rear script
  • Randy R.
    • March 1, 1983
    • 477
    67 rear script
    The 67 judging guide states "CORVETTE in chrome script lettering resting on a textured satin finish chrome bar". The bar on my script is not satin finish. It is standard chrome. Can anyone explain the difference?
    Thank you,
    Randy
    • 6954
    Re: 67 rear sript
    Randy, The reproduction emblems from Trim Parts is as you explain the factory emblems the chrome on the bar is satin finish. Trim parts makes a nice piece, the finish on the bar is a small detail. I don't know how the 67 Judges will judge this but I think that its not worth even a point.
    • Gene M.
      • April 1, 1985
      • 4232
      Re: 67 rear sript
      Disagree, if the emblem is different in texture and surface finish that is 20% plus 20% for configuration and finish or a 40% deduct. Randy made mention of non satin and deviation of texture both noticeable deviations from an original. Pretty is one ting correctness is something else.
        • 6954
        Re: 67 rear sript
        Gene, I think that the finish is just the issue. which I am not sure that every judge will see the difference. I know that you may have noticed this. so the point value is 5, 1 point would be a fair assessment ? I should have looked at the point value for the emblem. I had in my mind that all the emblems were bunched together. Thanks Ed
        • Gene M.
          • April 1, 1985
          • 4232
          Re: 67 rear sript
          What you say about every judge is properly true. But I give the explanation as the CDCIF scoring system details it. If one follows it or not, it is the NCRS path.
