L229 Engine code for 283 - NCRS Discussion Boards
+ More Options
Posts
  • Daniel S.
    • July 25, 2017
    • 117
    I am looking for a period correct motor for my resurrection of a 1960 vette. I see one on ebay that has a code of L229 - i thought this would be December 22 1959 but the add says it is from a 1961 OEM he also had the code FO203D. If anyone can help let me know or if you know of an engine. My vette has a number of 4225 which i believe was the last week of Feb 1960.
    Thank you - I'm a novice and will need lots of help.
  • Wayne L.
    • September 30, 1981
    • 233
    Re: L229 Engine code for 283
    You are correct, block was cast December 22, 1959. Engine was assembled on February third and was going into a 2-barrel passenger car with Powerglide transmission.
    • Daniel S.
      • July 25, 2017
      • 117
      Hi Wayne,
      Thank you very much,
      Dan
      • Edward M.
        • November 1, 1985
        • 1922
        Daniel;
        Is you car a manual trans or an automatic. Manual trans Corvette engine codes for 1960 start with the letter C, powerglide cars start with the letter D.
        • Daniel S.
          • July 25, 2017
          • 117
          Originally posted by Edward McComas (9316)
          Daniel;
          Hi Edward,
          I essentially bought the frame and body with no engine or transmission but I did buy and 4 speed transmission after i bought the car.
          Dan
