Re: melting power wire.
Just saw your post. I burned another front harness last week. I pulled it all out and reconnected. Also bought a new horn relay. Turned battery on and the front part is ok but it started to heat up around the fuse connector box on the firewall. All other wires are cool. Fortunately juice was going in for just a second so nothing melted. Since this another ground fault it must be an unfused wire. I think wire to ammeter is unfused so I have to check that and then keep looking. I had it running and driving but I was playing with horn relay again and that is when I burned out harness near that relay. . I also put in the drivers side of air con and I may have screwed things up there. Never a dull moment. Any other thoughts would be appreciated. Also taking an online course on electrical wiring in cars
