My aluminum winters intake for my 7014900R Fuel Injection Unit is 3758932. I assume this is atypical for judging since the guide says it should be 3748947. However, My 1959 GM parts manual lists 3748947 for 57-58 and then 3758932 for 59, and it was used for all other Fuel Injection combinations in 1959. Given the parts guide I'm wondering if there's a chance this is still a possible "original" combination for 59. I've got is a December 58 car.
I know the combination is not original to the car though. The last owner bought this and included in a box. The car had a carb on it, as is common with old Fuelie cars that have not been restored. Anyone ever seen this combination? How many points will I lose if I leave it as-is? I imagine with the port gasket installed you can't see the number either.
What functional difference? the top looks basically the same, but I notice the bottom distributor hole surface and oil filler hole bottom surface are open on the inward side on the 3748947 but closed on the 3758932.... With the oil filler bottom open like that, I guess more fumes escape? Not a big deal, aside from smog
With the distributor hole closed would the distributor get enough oil on the gear?
