1967 window cranks - NCRS Discussion Boards
1967 window cranks
  • Phil A.
    • April 30, 1982
    • 121
    1967 window cranks
    Have Al Knoch's door panels on a roadster. Window cranks won't compress enough to catch the keepers in the groove. Has anyone else had this problem with Al Knoch panels, and what did you do about it? Thanks in advance, Phil
  • Keith B.
    • September 15, 2014
    • 1588
    Re: 1967 window cranks
    With help push really hard back on the door panel while someone else slaps the crank really hard.
    • Michael H.
      • December 1, 1987
      • 730
      Heat up the door panel with a hair dryer on low and see if that helps.
      • Brian M.
        • February 1, 1997
        • 1840
        I agree, use a hair dryer NOT a heat gun.
        • Gene M.
          • April 1, 1985
          • 4232
          Be advised that too much pressure by the door panel against the crank it may pop off during use. That little “C” clip can only hold so much. There is a square wire version of this “C” clip that will withstand more force. I’ve had better success with Corvette America panels. But nothing fits like an original.
          • Phil A.
            • April 30, 1982
            • 121
            I guess I haven't seen one. Where would you get the square one? Thanks Phil
