Question for Joe Lucia and Our Engine Experts>What else-Optispark System - NCRS Discussion Boards
  • Larry E.
    • 1698
    For the owners(Me Included) of the above system we all know this was the "Achilles Heel" for that LT1.
    The LT1 at that time had a lot going for it with its sequencial intake system providing good hood clearance and
    good throttle response. Question: If one wanted to R&R that system with another system and still work with the car provided what
    would one do? The way the engine sits (set back) there is no room in the back to provide the standard distributor
    as we all know. I guess this question would be the best>What would Chevrolet done different if it knew the problem
    before hand with the technology at that time?? Distributor in front like the NASCAR RO7?? But that presents problems also with tight quarters.
    Idea's?? Thanks in advance--Larry
    Larry
    LT1 in a 1LE -- One of 134
    • 43281
    Re: Question for Joe Lucia and Our Engine Experts>What else-Optispark System
    Larry------
    Trying to make a conversion such as you suggest would create far more problems than it would solve. In my opinion, any such conversion, even if it were physically possible, would produce "terrifying" results.
    • Keith B.
      • September 15, 2014
      • 1604
      There is a conversion on the market that lets you use LS based coil packs. Search the Corvette Forum.
      Our site has more Crank and Cam Signal Kits, Connectors, Terminals, and Professional Series ECU Extensions than ever before!
        • 43281
        https://www.eficonnection.com/home/c...x-product-line
        Keith-------
        I wouldn't touch that conversion with a 10 foot pole. It might be OK for use in a hot rod using a Gen II small block but I wouldn't even considering using it for a 1992-96 Corvette with LT1/LT4. Among other reasons, I don't think the conversion would be emissions legal.
        • Chris S.
          • January 1, 2000
          • 1068
          MSD makes a crank trigger system that could replace the OPTI
          I looked at it to replace the OPTI in my SS
          1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
          Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
          1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
          1957 Corvette - FI 3 sp - Black and Silver
