Hi all,
I know that the water pump was installed before the engine was painted. That being the case, I assume the fasteners holding it to the engine block should be painted as well.
The only one I am wondering about, though, is the stud that resides in the upper driver's side hole. (On my '69 base model, this stud is used to hold the alternator adjuster bracket.)
Should this stud be painted orange like the three bolts, or was a bolt initially used in this hole (before painting) and later replaced with the stud (after painting)? And if it is the latter, what is the correct finish on the stud?
Thanks in advance,
Paul
Thanks in advance,
Paul
