70 Head Lamp Door Switch - NCRS Discussion Boards
    Infrequent User
    • January 25, 2017
    • 13
    Hi all-
    Is there a head lamp door switch, 3951239, adjustment one can make? The interior lamp on center console sometimes wants to light when the headlights are turned on saying that the light is lit when the doors are closed.
    Is this switch on the drivers side or passenger side of the head lights?
    Many thanks.
    John
  • Dan A.
    • February 1, 2004
    • 212
    Re: 70 Head Lamp Door Switch
    There is a switch on both sides, and they do fail occasionally. From my recollection there is no adjustment but others may be more knowledgeable than I am about that.
      Infrequent User
      • January 25, 2017
      • 13
      Thanks Dan
      • Mike F.
        • April 25, 2011
        • 668
        Either head lamp door switch can/will illuminate the interior center console light independently of each other, which means the warning system will function correctly with only one switch plugged in.
        To trouble shoot a bad switch, simply unplug one switch at a time and see if the problem goes away. If it does, that's the bad switch. In the unlikely event that both switches are at fault, the problem will remain no matter which side is unplugged.
        • Rick N.
          • August 25, 2017
          • 141
          If the headlight door linkage isn't locking in place correctly in the up position, the buttons won't depress and light stays on.
          If this is the case then the linkage will require adjusting.
          This system is a closed circuit until buttons are depressed which opens the circuit and shuts the light off.
          Unplug one switch at a time to verify which is the issue.
          Then verify if switch is the issue or linkage adjustment.
          Good luck !!!
