1967 Left Rear Inner Splash Shield Panel Holes - NCRS Discussion Boards
  • Gary J.
    • April 1, 1980
    • 1245
    Would like to know why these two 1/4 inch holes are still present on the left rear inner fender splash shield on a 1967. I know that the two holes were used for '65 and '66 to mount the antenna bracket. The bracket was not used on '67. I have confer with two other owners which have a January, a June built cars. This is an April car that I am working on. You would think since the bracket is not used on '67 that the holes would not be present.
  • Peter M.
    • May 30, 2013
    • 359
    Re: 1967 Left Rear Inner Splash Shield Panel Holes
    Gary,
    My mid April 67 coupe has the same two holes. I am interested to hear what others have to say.
    Did the other two cars you mention have the holes?
    Kind regards
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11345
      Every 67 I have seen or worked on has them.
      • Peter M.
        • May 30, 2013
        • 359
        Thanks Richard.
        • Donald H.
          • November 2, 2009
          • 2586
          My mid May 67 has them
          Don Harris
          Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
            • 6950
            I was thinking, are they possible electric antenna mounting bracket holes ???
            • Gary J.
              • April 1, 1980
              • 1245
              Yes that is for electric antenna mounting bracket holes. Seems the holes are there on all '67. My question is why they are still there because no bracket is used for '67. I can see the holes being there at the start of production and then running out. I know of a June built car with the holes still there.
              • David B.
                • April 1, 1988
                • 42
                For the same reason that, for example, the underside of 'all 67 small block hoods had an opening for the installation of the '66 hood emblem. 1967 was a lame duck model year before introduction of the shark body style. From GM's standpoint, why pay extra for retooling a hood or splash shield that was perfectly functional for the last year of that body style? Many other examples exist, such as SB top shielding that still has a separate slot on the back for the FI ground strap.
                • Tammy D.
                  Infrequent User
                  • July 31, 1996
                  • 15
                  14478 and 16308 have the holes.
                  • Tom K.
                    • February 26, 2008
                    • 167
                    17605 has the holes
                    • Tom K.
                      • February 26, 2008
                      • 167
                      17605 has the holes
