'65 396 L-78 Fan Blade Info Request - NCRS Discussion Boards
  • Mike B.
    • July 31, 1994
    • 843
    Good Evening Guys,
    I've been reading a lot of old posts and came across one that we'd discussed (way back) about the proper fan blade for '66 and '67 big block engines. It was determined that fan blade #3888366 was correct with or without AC. Lots of closeup shots of the blades and their stamps "H", "FRONT", "66", and "W". Great info that really helped me.
    But I have an earlier '66 427 car with what could've had an installed leftover 396 fan blade. Pretty sure it's original to the car. My car falls into that anomaly of a long lull between the engine cast date and the assembly date.
    All this aside, I didn't see any actual photos of '65 396 fan blades on any of the old posts about #3872792 blades. Could anyone that has photos of this unique blade post them? Pitch, rivets, stampings, dimensions etc....Any and all would be much appreciated!
    I'd really like to compare my blade against true 396 originals.
    Take care, Mike
  • Mike B.
    • July 31, 1994
    • 843
    Re: '65 396 L-78 Fan Blade Info Request
    My Blade. Mike
    • Mike B.
      • July 31, 1994
      • 843
      A few more shots of my blade. Thanks, Mike
      • Mike B.
        • July 31, 1994
        • 843
        Forgot to mention these facts about this blade.
        -17" inches outer diameter.
        -Front 4 hole plate has only "Front" and "H" stamps. No "66" stamp.
        -Back of blade has no "W" stamp on any spoke
        -Flat radial circles on front rivets
        -Recessed flat rivets on rear
        Unfortunately, I'm away on business and I don't have a blade pitch measurement. But there is a side shot of the blade showing pitch.
        Hope to hear from the experts. I've always wondered if this is a real 3872792 fan blade.
        Thanks guys, Mike
        • David L.
          • July 31, 1980
          • 3310
          Mike,
          I have studied and owned many Chevrolet and Corvette fans over the years but I have never owned a 3872792 fan. However, my friend "Logic" tells me that the 3872792 fan is very similar to the 3888366 fan (stamped "66"). I have owned at least a half dozen 3888366 fans over the years. Here is what I have from my notes:
          3888366: (66-67 Corvette 427, 68-70 Corvette)
          5 blades
          5 rivets per blade
          17.50" dia.
          5.93" blade length
          4.00" blade width
          2 1/4" pitch
          3" bolt circle
          3872792 fan (65 Corvette 396)
          5 blades
          5 rivets per blade
          17" dia.
          5.68" blade length
          4.00" blade width
          2 1/4" pitch
          3" bolt circle
          Both fans were made by Hayes-Albion.
          Since each blade is 0.25" longer on a 3888366 fan then the fan diameter would be 0.50" larger resulting in slightly more air flow. If your fan is 17" in dia. and the pitch measures 2 1/4" then I would say that you have a 3872792 fan.
          Dave
          • Mike B.
            • July 31, 1994
            • 843
            Thanks for the reply David,
            Excellent info! I'll check the blade's dimensions when I get home. I'm especially interested in the pitch measurement which wasn't listed on the diagram above.
            Had an old friend call last night who saw my photos and said he has this exact same blade. Looking forward to comparing them side by side.
            Take care, Mike
            • James W.
              • December 1, 1990
              • 2673
              Mike,
              I've attached some pictures of the fan blade off of a late production 1965 Corvette equipped with a 396, VIN 2216xx. The car went through all levels of flight judging on 2014 with no deductions for this fan blade. Hope these help.
              James
              • Mike B.
                • July 31, 1994
                • 843
                Hello James, Thanks for the shots of your 396 Fan. I think our fans are the same. There's only one difference that I can see from your photos. My fan has "FRONT" and "H" stamped on the front. See my pics above. No other markings anywhere else on the part.
                I see your fan has the "H" stamp but I don't see any other marks. Do you recall any other markings on your fan?
                Thanks again for the great photos! Mike
                • James W.
                  • December 1, 1990
                  • 2673
                  Mike,
                  There are no other letters or numbers on fan besides the H.
                  James
                  • Tom D.
                    • September 30, 1981
                    • 2145
                    For what it is worth, here are photos of the rivets on a Paragon REPRODUCTION 396 fan. (Check the photo names - The "back side" or "engine side" should be photo number 2.)
                    https://MichiganNCRS.org
                    Michigan Chapter
                    Tom Dingman
                    • Mike B.
                      • July 31, 1994
                      • 843
                      Thanks Tom,
                      Wow. Pretty close to the fan in question (pics above in my post #2 & #3). That blade was on my '66 when I bought her in Aug '88. Normally repro stuff is way off!
                      Thanks, Mike
                      • Loren L.
                        • April 30, 1976
                        • 4104
                        FWIW, the Oct 1, 1967 Pts Bk in Gr,1.064 lists "65 Corvette w/Sp. H/Per (396)" all by itself at 17" dia 5 blades #3872792 and @ $7.85.
                        • Mike B.
                          • July 31, 1994
                          • 843
                          SOLD!!!
                          • Andy C.
                            1963-4 Team Leader
                            • April 1, 1998
                            • 119
                            Mike,
                            I have 2-396 cars, both have the same fan with a "W" only and measure 17" with a 2-1/4" pitch. One is a June car and the Other is July. I did have a 66 that had a Fan like yours.
                            Andy
                            • Mike B.
                              • July 31, 1994
                              • 843
                              Thanks Andy!
                              Was your '66 a 425hp or a 390hp car? Any old file shots of it's fan?
                              A non-related question here. Do either of your 396's valve covers have "clover" head mark bolts/screws?
                              Mike
