Quiet Air Compressor - NCRS Discussion Boards
  • Roger W.
    • January 29, 2008
    • 572
    #76
    Re: Quiet Air Compressor
    Thanks Gary. I will be ordering The Eastwood Compressor. It fits the bill for my needs.
    • Gary R.
      • April 1, 1989
      • 1804
      #77
      Did you go with the single or three phase unit? I'm guessing single phase like I have? Let me know how works for you, what is the current lead time?
      • Roger W.
        • January 29, 2008
        • 572
        #78
        I ordered the Eastwood compressor today. It is 240 volts. The order taker said that I would the get compressor in about a week.
        • Gary R.
          • April 1, 1989
          • 1804
          #79
          Good deal, hope it works out for you. Send some pictures when you get it to see if there are any changes to it. I run mine without the cover. Keeps it cooler and allows me to check it.
          • Roger W.
            • January 29, 2008
            • 572
            #80
            Gary. I just got my Scroll compressor going today. I have had it for 2 months, but between wiring issues and numerous other unrelated things that I had to do I finally heard how quiet the operation is. for me, I think that it will provide all of the air that I need. One thing that I was not prepared for is the length of time that air continues to come out of the pressure control after the motor shuts off. (About 10-15 seconds). I called the Eastwood Technical department and they said that was normal. I attached the latest photo from the Eastwood Website. I am terrible at uploading photos.
            • Gary R.
              • April 1, 1989
              • 1804
              #81
              Yes the unloader bleeds down about 30 seconds on mine. Keep the oil at 1/2 the dipstick, if you fill it to the top of the line it will blow out oil. Did you get a cover with yours or did they eliminate it? Mine loads about 110 psi and unloads about 145 psi.
              • Roger W.
                • January 29, 2008
                • 572
                #82
                No. I did not get a cover and the website photo does not show a cover. I used one of the holes that I think was probably used for the cover to attach a brace to hold the regulator and filter bowel.
