U Joint can any one identify these u joints - NCRS Discussion Boards
  • Dan P.
    • December 1, 1990
    • 683
    Does any one know the correct years for these u joints . On has a Bow Tie on it . Seams to be the most common one.
  • Loren L.
    • April 30, 1976
    • 4104
    Re: U Joint can any one identify these u joints
    _847_22????
    • Dan P.
      • December 1, 1990
      • 683
      part number 3847922
      • Alan D.
        • January 1, 2005
        • 2054
        You mean these ? They are original production parts. Still have on my drive and half shafts, just not sure how far I can drive.
        • Dan P.
          • December 1, 1990
          • 683
          pull you caps off and look where the needles run on the cross piece . If the needle bearing have not worn into the cross piece your good to go . The one on the right does not look original .Has to have the circle in the middle . The one were the cap is missing looks OK.What year is your car.
          • Alan D.
            • January 1, 2005
            • 2054
            Believe the left unit is for half shaft, car is Mar64.
            • Dan P.
              • December 1, 1990
              • 683
              The one on the left is what i have pulled out of original drive shafts . The one on the right may be half shaft . I do not know .
              • Loren L.
                • April 30, 1976
                • 4104
                3847922 shows up as for a "64 CHEVY" which I assume =s Chevy II
                • Dan P.
                  • December 1, 1990
                  • 683
                  I looked in the 1959 passenger parts book and for 53-59 Corvette U joint repair kit is 3741635 cost $12.05 But 55-59 passenger car and truck was 3713926 $8.60 .They took the same U joint . But years ago i has NOS U joint repair kits That came with the u bolts and hard ware. The 3741635 show it takes 2. So the front does not take u bolts ????
