Did it all. Bled the brakes every way, gravity, wife, suction, and pressure, replaced master cylinder, and finally the rubber brake lines in the front, all with no change. The pedal firms up about one half inch from the floor, stops the car but you can't lock up the brakes, not enough pedal. The question is, is there an adjustment in the up and down movement of the pedal. I noticed a screw type adjustment on the end of the shaft that pushes the piston forward inside the master cylinder. That is the only thing that I can think of that might be left that I have not tried.
Is there any specification as to how that should be adjusted, if at all? It is power brake car.
