68 Upper Control Arm Bushing - NCRS Discussion Boards
  • Rich G.
    • August 31, 2002
    • 1406
    I’m not sure I have the correct bushing in my 68. It appears there is the bolt, the lock washer, the metal washer then a rubber O ring. The O ring is torn on the rear on both sides. When I look for replacements the catalogs don’t show an O ring but a bushing that looks like the top of it would serve that purpose.
    A picture of the correct bushing would be great.
    Rich
  • Joe R.
    • July 31, 1976
    • 4552
    Re: 68 Upper Control Arm Bushing
    Rich,
    Here's pictures that may help.
    These are repos but should guide you somewhat.
    The lowers are on the left and uppers on the right.
    JR
    • Rich G.
      • August 31, 2002
      • 1406
      Joe
      Thanks very much. It looks like either the outer piece is separated or somebody in the dim past put an O ring under the metal washer to mask a deteriorating rubber of the bushing.
      I found a youtube video on replacement which helps me understand.
      Rich
