56 Rear shock access hole covers - NCRS Discussion Boards
  • Mark S.
    • July 31, 1983
    • 663
    Were the 56 rear shock square access covers on when the interior was painted or are they left natural unpainted? Thanks!
  • Patrick S.
    • January 1, 1988
    • 209
    Re: 56 Rear shock access hole covers
    I used a piece of "gorilla tape" to seal these holes in my 57.
    • David S.
      • December 1, 1982
      • 310
      Mark leave the covers natural. I have attached pictures from a bowtie car
      Dave
      • Mark S.
        • July 31, 1983
        • 663
        Dave:
        Thank you very much for the pictures! They were very helpful.
        Sincerely,
        Mark
        • Rod K.
          • 443
          David,
          AIM Sect J, p3 shows "masking tape" prior to rev date 3/25/57 when the "3740260" seals were added. What is the approx. build date of your car if you don't mind? It appears it had the seals, not tape, correct? If yours are actually tape of some sort, could you elaborate on the description a little please. Trying to clarify what would be correct for my Nov '56 car. Thanks for your help.
          • Mark S.
            • July 31, 1983
            • 663
            The build date on my 56 is August 7, 1956. It now has 50,000 original miles on it and I traced it back to 1958 at Midway Chevrolet in St. Paul, MN. I contacted the owners of Midway Chevrolet; and they did not retain the records for 1958. It had seals on it and not tape. There were several other items, like a 57 radio, that suggests that this car was in the changeover of parts to the 57 models.
            • Rod K.
              • 443
              Mark,
              Could you provide dimensions of the seals, please, length, width and thickness and type of material? Thanks for your help.
              • Mark S.
                • July 31, 1983
                • 663
                The seals are approximately 3" by 3", thin (but thicker than tar paper), tar paper type of material. Hope that this helps!
                • Rod K.
                  • 443
                  Yes, Mark, helps very much. Thanks a lot.
